Aio cooler or tower cooler
bal723
so i recently got into problem of choosing a cooler.
I have a choice from 2:
Aorus tc700 tower cooler
Aerocool likai 240 aio cooler
But i think that with aio radiator in front of my case (aerocool cs-107) my gpu wont fit (gtx 1660 ti aorus 280mm) because max gpu size is 286mm, so what to go with?
(cpu is i3 10105f btw).
Such odd cooler choices, i3s could use stock cooler and it will run fine, even non K i5s too.
I wouldn't buy cheap unknown AIOs, AIOs are prone to failure as it is, going with cheap unknown ones is just unwise.
That said, any cheap air cooler is the better choice.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Both are overkill for a Core i3. Something like a DeepCool AK400 would be cheap more than enough for that chip. Those things can basically run with the stock cooler. It's only the higher end i5s and i7s you need to worry about. There are also the Zero Dark variants of the AK400 if you want to go for a clean all black aesthetic.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Havent seen any big reviews (seems like its not sold in a lot of places) but cheap AIOs are usually worse than tower coolers anyways. But anything more than a basic tower cooler is overkill on an i3
Chicago Bears fan, Bear Down
Somethink like 90% of AIO's are made by the same company...
Well yes, but nowadays some small companies have made their own radiators to avoid those trademarked designs.
Such as ID-Cooling, IIRC big company too such as MSI.
So unless we know for sure, I wouldn't put my money on it and say, "hey they all use the same radiators and pump anyway".
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
Deepcool ak400 is more expensive than both aio and tower in my local shops
Aerocool sells some of the most popular pc cases in russia like aerocool cylon, aerocool aero one mini and aerocool bolt mini, their quality was good in last years, so i can say that its pretty safe to buy aio from them
I need a cooler for a future, so i could upgrade to i7 in next 6 years, and i3 would be a lot colder with them anyways
1 hour ago, Somerandomtechyboi said:
What country and budget for cooler?
Russia and 2500 rubles (50$)
Can you link us to the stores you're looking at?
im buying it from used market ( avito.ru )(its like russian ebay)
I am Canadian but reading your posts with a Russian accent 🤘🏻
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
Depending on how much you want to spend,
SE-224-XT Basic: https://www.avito.ru/yoshkar-ola/tovary_dlya_kompyutera/id-cooling_se-224-xt_basic_2688786294?slocation=621540
or SE-225-XT Black V2: https://www.avito.ru/voronezh/tovary_dlya_kompyutera/kuler_cpu_id-cooling_se-225-xt_black_v2_novyy_2536276997?slocation=621540
Good job comrade
8 minutes ago, WoodenMarker said:
I feel like they wont match colors in my system
How? It's black.
On 12/4/2022 at 11:47 PM, WoodenMarker said:
How? It's black.
Its kinda ugly
