Help with headphones
Studio75
I bought a pair of Beyerdynamic DT 770 PRO - 250 OHM LE DT 770 Pro 250 ohm with an old pc build about 3 months ago and now since I have moved my old pc into a new case and upgraded my GPU the sound is bad. It sounds muffled and not as full as it used to sound. Also, the sound is much quieter than before I used to have my sound at 30-40 for a comfortable volume but now I have it cranked up to 100, and it is on the quiet side.
I've tried updating drivers and windows sound settings but none of them work.
Syba Sonic DAC USB. 250Ohm might be too much for many onboard audio solutions.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
just get something like a fiio ka3/moondrop dawn. both less than $100 but will drive 250ohm headphones no problem.
Ok, I'm not entirely sure but I guess I can see that happening. The thing that does not make sense is that I have a 750-watt PSU and before I had a 1070 and it was perfect. All I changed was the Gpu.
I thought you changed the motherboard.
Use Iobit Driver booster to update the driver.
Ok I will try it should I update all of the other outdated drives such as?image.png.b0613f3279dc3f6fcee2e38b211c2bf1.pngimage.png.89eff0a2d14d07150957790ce0a257b0.png
Yes.
21 minutes ago, 191x7 said:
Yes.
After updating and restarting the loading times for everything google relates is super super slow including internet speed test even though i am getting 200 down and 20 up
Ok i fixed the internet issue but now windows thinks my headphones are speakers and no mater what i try changing it reverts it after I installed the new driver.
That is normal.
How's the sound?
1 minute ago, 191x7 said:
That is normal.
How's the sound?
I think I just fixed it but it still  not as loud as it used to, any suggestions? It sounds normal now so its fixed and I fixed windows thinking its speakers.
Are you using the DT770 with your motherboard? If yes, onboard audio are usually trash and I speak from experiences. Externals are better.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
Apple Dongle should be enough
I am using the HD audio port on the Chassis. So yea/
No one has addressed the fact that it USED to be acceptable
Are you using the front panel connectors?  If so use the back panel, that's the only thing that should have changed.  Unless you are using the monitor output which I wouldn't recommend.
Anyways I can second the Syba for a budget dac/amp.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
