Arctic Liquid Freezer 2 v Custom Loop
Solved by freeagent,
2 hours ago, mikeyw64 said:IMHO one of the big advantages of any for of liquid cooling (AIO or custom loop) is generally speaking it will be quieter than a fully air cooled config for the same cooling efficiency
Yup, until the coolant reaches the same temp then you’re in the same boat as an air cooler. That is why I say AIO are E-Waste. No better then a top air cooler, and you have to throw them away after a few years if the unit cannot be topped up. If you are going to do water get a real loop not those pretend ones
