Would adding a shroud around my GPU fans lower temps.
Solved by PriitM,
3 hours ago, SircarrotII said:
These fans dont do much at all right now. The fling most of the air out the sides. You are better off taking the original shroud off and strapping couple of regular PC fans WITH shrouds/cages on.
Where did you even get this idea?
What is that card?
what those fans?
Found a Linus video for your education
