Id like to overclock my i5-4670k to 4.4 GHz, any recommendations on cooling solutions are welcome
Im sure I have everything I need to run any cooling solution except water cooling its self.
NHD-14 for if you want air or H100i for water cooling.
(sneezes) "Sorry I'm allergic to bullshit"
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957755
There's better 240 AIOs out there than the H100i.
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957758
which cooling solution is better in your opinion?
wait for the NDH-15, it is better than the old 14
get the H100i if you want good looks, with a side panel window on your case
you can also overclock more with an H100i, to about 5GHz with a decent processor
the noctua cooler is more for silence and people who dont like watercooling
you get good temps with that one too
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957801
personally I am a water cooling guy but I have had air and water in my system and they are both really the same just one is a big chunk of metal and the other is a long chunk of metal. If you are unsure what you want I would suggest going NHD air cooling as long as your ram and case support it(massive heatsink).
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957809
I think the ones you're speaking of aren't available in the U.S. though.
He can get the Glacer 240L which is basically the H220 for the US since it was designed in colab. with Swiftech.
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957857
NH-D15
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957859
For optimal noise levels I would go with the NH-d14/15 as it runs nearly silent, although it is quite big and fills a side panel window. That thing kept my cpu really cool even at 1.35v so I have no prblem recommending it for overclocking. The only reason I swapped out to an h100i is my brother wanted my nh-d14 for his super silent rig :/
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957867
what case would you recommend, do you think an i5-4670k would go to 5ghz?
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957883
Extremely unlikely you'll get a chip that can overclock to 5ghz.
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957890
i like the 212 evo, dont know if you can get the performance you need from that
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957891
probably not, but thanks for the suggestion
yeah it is good for the exra 30$ over stock but compared to water cooling i dont think it compares
My Rig
Total: $2074.22
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1957957
it depends on the CPU if it overclocks well
some people have a core voltage of 1.4v and cant get over 4.4GHz
i have 1.15v at 4.6GHz
it all depends, but a liquid cooler removes most of the temperature bottleneck for overclocking
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1959681
https://linustechtips.com/topic/146609-i5-4670k-cooling/#findComment-1960505
