Need help with picking out parts for a server.
Since Minecraft relies most on one-core boost, processors like Ryzen 5-5600 or Core i5-12400 (or above) are favorable. Indeed a GPU (even integrated) is not required for a server as it can be managed over remote console, and hence may or may not be a problem; but if needed, then Core (non-F) or Ryzen 7000 series is required.
Also, a stick of 1TB or 2TB NVMe SSD may be preferable for hosting the whole map, and perhaps another one or HDD for backup if desired.
I don't really know why 8 drives/SATA ports or more are needed... Four 16/18 TB drives with RAID 5/RAID Z1 have been a massive setup for anything to store. In any case, with processors above, only X670 boards could have 8 SATA ports, whilst others only have 4/6, so that an expansion card for SATA would be required.
As for memory speeds, it should be fine for picking up DDR4-3200 or above, & they may contribute modestly to overall performance.
For power supply, 400W may be required for 10 HDDs, but 300W or fewer for no more than 4 HDDs (given that each drive draws 20-25W when power-on).
