NEED FAST HELP PLZ! PC wont start after BIOS update QCode Ad and PC wont boot
B4rt997
Go to solution Solved by IkeaGnome,
2 minutes ago, B4rt997 said:
Enter BIOS, Advanced mode.
Navigate to
Advanced Menu -> AMD fTPM Configuartion
TPM Device Selection: Firmware TPM
Save & Exit
I cannot belive it that was it AMD fTPM Configuartion
Now fully starts and loads windows !!! :DDD
Always nice to get a fresh set of eyes on things when I start over thinking things @Senzelian
Only thing left is to re enable XMP for your ram to run at it's rated speed. Extreme Tweaker> Ai Overclock Tuner> DOCP 1.
Also, Give it to Senzelian. They found it.
I’ve built this pc myself about 5 years ago or so everything was working fine, I guess. I didn’t have any issues but for some reason I decided it be good idea to update the BIOS last bios update was from 2018. Updated my Crosshair VI HERO to latest bios update and not I’m stuck.
It shows Qcode Ad and on the monitor, it stuck on “Please press DEL or F2 to enter UEFI BIOS setting” but nothing works here F2, DEL and F8 keys doesn’t work
This is what I am runing with
https://uk.pcpartpicker.com/user/B4rt997/saved/#view=tTr8dC
1 minute ago, JoshCanHearYou said:
did u clear cmos?
Yes,
What I did is on this motherboard there’s a button cmos and when shut pressed to 10secs and after that powered pc on
didnt work
Just now, B4rt997 said:
Yes,
didnt work
After clearing cmos it takes me back to BIOS after pressing F1 and do I have to change any settings?
Uhh I'm not sure, I've never owned an asus mobo. Just normal troubleshooting steps.
Did you have CSM enabled before? If the drive was an older install of Windows and using an MBR partition table you may need to reenable CSM to be able to boot.
Code AD means "ready for boot event" according to the manual for this motherboard.
That suggests to me that the BIOS update was successful.
You might have to change the boot order. Have a look if it is still correct.
Yes, XMP will be disabled so you'll need to go back in a reset that. You might need to put your boot priority back to how it was and as @GuiltySpark_suggested you might have to go back into CSM or Legacy boot mode.
It looks like ASUS might also have enabled TPM and secure boot by default with their BIOS updates that are "Windows 11 ready" so you'll want to disable those too if it automatically enabled them and you weren't using them before.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
It boosts from the ssd drive where the windows is
about the CSM should I disable/enable and which one should I select UEFI and Legacy OPROM or one of them
sorry I have no idea what im doing when it comes to this stuff
I was playing with the boot settings and now I have black screen, no messages or text
the code still stays the same Ad
Reset CMOS if you can't get into BIOS. Doing that will reset anything that just got changed.
What I would do is try it in Auto first. Does your boot drive show up as an option in the "Boot Option Priorities" section of the Boot part of the BIOS?
Are you using Windows 10 or 11? That will give some hints to other settings that were probably not enabled before.
Project Hot Box
Oppbevaring
Boot Drive shows in the boot option priorities and as defult is on the boot drive
the auto in CSM dosent work thill same issue
I edited while you were replying. Are you on Windows 10 or 11? That will give some hints to other settings you might not have had enabled.
Project Hot Box
Oppbevaring
Still on Windows 10
Still on Windows 10
In the boot menu, disable Secure Boot. In that boot menu I would try this. CSM (Auto), Boot Priority (Your drive with Windows installed on the top of the list), Secure boot (off)
Project Hot Box
Oppbevaring
The Secure Boot Option Is Enabled and cant disable it only can change the OS type
Other options applied and no success  ends on black screen
Can you post a picture of what you can change for Secure Boot?
Project Hot Box
Oppbevaring
Now there’s a 98 code after booting and after back to Ad qcode
sure that’s what I have available
Do you have a Windows install USB? Don't uninstall and reinstall yet, but I'm curious if it will boot into that USB drive and try to install Windows.
Project Hot Box
Oppbevaring
No I dont but I have a ssd drive that I can install the windows and try if off from there
BUT (i dont want to lose everything thats on the pc)!!
If you put a Windows installer USB into the computer, but don't go through with the install, we can see if the board wants to boot but a setting is wrong for your drives or if it's just not wanting to boot right now, and not delete anything from your computer.
Project Hot Box
Oppbevaring
installed Windows installer USB on the drive and plugged it to computer reset it and nothing happened
I am supposed to click something?
Your computer just goes back to BIOS? Or it just stays at a black screen? In bios, set the USB as the highest boot priority.
Project Hot Box
Oppbevaring
When I boot Override from the disck there the windows is it throws be back to BIOS
when I boot from the disk with windows it goes to AE and then back to Ad and black screen
AE is Legacy Boot Event. It's trying to boot.
Out of curiosity. If you go into Sata Configuration, the board is in AHCI and not RAID right?
@Senzelian @GuiltySpark_I feel like there's something stupid simple we're missing here. Ideas?
Project Hot Box
Oppbevaring
