What are the best Corsair fans for a radiator?
HungryHamster
I will be getting the 360mm iCUE H150i ELITE LCD Display Liquid CPU Cooler and I would like to do a push/pull configuration. It comes with 3 Corsair ML 120 RGB Elite PWM fans. I'm wondering if I should get 3 more of those to attach to the other side (to pull air in) or if I should consider one of their other fan options?
H150i is pretty meh, destroyed by liquid freezer ii and stupid overpriced usually
If you want an lcd just buy a cheap hdmi panel or something and stick it on the case, much bigger and more useful/functional than a miniscule aio block display
Best rgb fans atm for all i know are the arctic p12/120 (0db) argb fans which perform equivalent to noctua fans, you can get the p12 0db argb on the argb versions of liquid freezer ii aios
corsair fans with aio are different from signals / 3pack unless they finally sold them witch means the rpm will be different...
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
