LG Monitor [22MP55HQ] fading out into green&black and glitching out
Update: So I was just about to give up on this display, since the board itself was not an issue (verified by using a new board), and I was taking the monitor apart to throw it away, but decided to just poke around a little in case it was a loose connection somewhere or a broken cable that I missed.
I noticed that one spot on the thin wide pcb (that runs along the entire bottom) that is glued to the back, would cause the issue to go away when touched, but only by a finger, not plastic. So some sort of resistance or capacitance change fixes it.
I couldn't pin point which part was being affected exactly, and nothing too unusual showed up when measuring, so before putting it away to take a look later I sprayed the rough area with isopropyl alcohol to clean it off from all the finger grease I introduced... and now it's not glitching at all. It's been on for about an hour and, no glitchiness... Odd issue. Maybe moisture mixed with some residue? Or a tiny bug took a tiny poop... who knows.
But yeah, I just wanted to drop this update in case it ever helps someone. The rough affected area was this, right under the RT6807A chip.
I am still not 100% sure it's fixed, I don't want to entirely get my hopes up, keeping it on until it glitches again, and if it does, the cause it somewhere around here, or related to this spot. Otherwise, if it doesn't, I've got my monitor back and can set myself up with a triple monitor setup.
