12700k - Formula 690 - 5600 Dominator - would not post, boots now, runs like crap, sound issues
Solved by Kangaroo Factory,
I solved it. Riser cable.
The initial problems were cmos issues due to the computer being off for week. Should have never happened. Probably an Asus issue.
However, while taking it apart to solve my initial problem, i must have nicked the riser cable. The last three prongs on the riser cable had lifted off.
The tiny lack of uniformity caught my eye while i was swapping in another known power supply. It doesnt really show in the picture.
I plugged the gpu directly into the mb, and the audio issues were gone.
