I formated my western digital ssd. Help!!
Xyd9
I was trying to format a flash drive to put some work files on it, and I accidentally formated my ssd. If you know a way that I could use to recover the data I lost please help. If I don't get this data back soon there is a big chance I might loose my job.
I've mucked about with Recuva before, you could give that a shot. If it was just a quick format it shouldn't have overwritten anything, meaning you can likely get all the data back fine.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
If your job is on the line, Id power off your system and send it to data recovery. With ssds Trim wants to run in the background, and that will make it much harder to recover data if that runs, so try to keep it offline if possible
I've used Recuva before as well, I had good results.
Desktop: Intel i7-13700K / Asus ROG Strix  z690-e / Nvidia 4080 FE / 32GB DDR5 Corsair Dominator / 2TB  WD SN850x  / 48" Lg C2 & 27" Asus ProArt
Plex Server: Dell OptiPlex 7010 /  i7-13700 /  32GB DDR5 / 1TB Samsung  990 Pro / Ubuntu
Laptop: M2 Macbook Air / 8G ram / 8core CPU / 10core GPU / 512GB SSD
NAS: Synology 1821+ , 2x Synology RS819 = 200TB
First off, Sorry about the Drive bro. Secondly, The drive is Formatted. There is no easy way to get that data back. However, Data recovery Services exist for this very reason. https://www.werecoverdata.com/ Are the Number One data recovery company with the most experience in the field. You're gonna pay for that Experience though. My personal experience with an HDD was $1500 for the Service. (Yikes).
Here is a resource to look at to get an idea on what to do if Data Recovery isnt an option:
https://www.cleverfiles.com/howto/ssd-data-recovery.html
Marline
Top Loop:
Thermaltake Pacific PR2U Dual 5.25" Bay D5 Pump/Resorvior Combo / EK ZMT Tubing / A mixture of Chrome Plated Brass Rotary Fittings Bit Fenix and Alpha Cool / Alphacool NexXxos 280mm 45mm Thick Copper Pass-through Radiator / Alphacool NexXxos 140mm 45mm Thick Copper Radiator / XSPC G1/4 1/2ID Chrome Compression Fittings / Freeze Mod AM4 CPU Waterblock / 3x Noctua Redux 140mm fans
The Bottom:
Custom Made 2mm Thick Steel PSU Shroud / Aqua Computer Aqua Tube POM Reservoir / Alphacool Eisdeck 5 w/D5 655 Pump / EK ZMT Tubing / Alphacool 45° Chrome Plated Brass Rotary Fittings / Bitfenix 90° Chrome Plated Brass Rotary Fittings / Alphacool Chrome Plates Brass Pass Through Fittings / Koolance QD3 Quick Disconnects / Bitfenix Full Cover Water Block 2080ti / Alphacool NexXxos 200mm 45mm Thick Copper Radiator / Noctua Chromax 200mm Fan / The fluid I used for both was EK Cryofuel Acid Green
Computer Specs:
Thermaltake F31 Suppressor / Ryzen 9 3950X / 32gb G. Skill 3200mhz RAM / Asus B550-E motherboard / Zotac RTX 2080 ti 11gb / EVGA 1000 GS PSU / Samsung 970 Evo Gen3 NVMe SSD / Western Digital SN850X Gen 4 NVMe SSD / 4x PNY 120 gb SSDs in RAID 0 / 1x Spectre 512gb SSD / 1x Patriot 240gb SSD / 1x 1Tb Western Digital Black 7200RPM HDD / 1x 2Tb Seagate 5400RPM HDD / Windows 10
If it was a quick format (what Windows usually does unless you specifically tell it not to) it shouldn't have overwritten much, if anything. So a self recovery with free software should work fine.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
