Will my aio liquid and or fans freeze?
29 minutes ago, TurkishBTW said:Will my aio liquid and or fans freeze i live in new york and heating doesnt work in my house and my room temp can get in the negatives and im worried the coolant in my aio will freeze or like my fan will freeze and cant move are any of these possible?
Uh… does your room temp actually get negative? Cuz if so, you probably don’t need to worry about the PC you couldn’t afford, but should spend money and energy figuring out how to fix your heater. Negative indoor temps can easily cause death, this is actually not a joke and is a serious issue - as the above post said it would be illegal for a rental property to not provide heating for this reason. If you own your house, obviously it’s on you…. But that isn’t something to neglect, if your house is freezing, pipes will freeze, and expand, and will cause pipes to burst which will turn into a massive issue.
But, thankfully, no, the AIO likely won’t freeze as fast as pure water. So as your freezing to death over night with pipes that are likely going to burst…. You can rest assured your AIO is likely ok since its likely a glycol mix.
