DVI PORT NOT WORKING
Solved by gbkendall,
So, most cheap DVI cables are uni-directional, and are only good for transmitting a DisplayPort signal (input) to a DVI monitor (output).
Not a recommendation by any means, but you'd need an active cable (something like this) to go from your DVI port on your PC to the DP on the monitor.
aren332 ·
Harry_rn ·
Posted in Troubleshooting0 -
1
1
kim921 ·
Posted in Build Logs2 -
_y0sh ·
Posted in New Builds and Planning2 -
James Jonathim ·
Posted in Troubleshooting1 -
6
DoDoTheGoD ·
Posted in Graphics Cards4 -
robjt ·
Posted in Troubleshooting16
