Does SSD custom over-provisioning persist between operating systems?
Shutset
Does anyone know how to control the overprovisioning on SSDs on Linux or BSD?
So far, I've only managed to increase the overprovisioning of my Samsung NVMe drive, using Samsung Magician
but I really want to be able to do the same for my SSD's in my Linux computers.
If I can't do it from within Linux or BSD, could the new overprovisioning settings I set in Windows
be carried over to other operating systems?
Let's say I increase the overprovisioning of an SSD to 50% on Windows, using Samsung Magician,
then remove Windows and install a Linux distro on it. Will it still have half of its storage capacity overprovisioned?
Thanks.
No, you'd need to partition the disk yourself and leave 50% of it free. But why would you do that? The built-in overprovisioning is more than enough for years of usage.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
You really don't need to worry about writes killing a modern drive. They can take a lot more than any normal user could put on them(Im killing 8 ssds for a test, and they have lastest >6 months of continous writes already, and this is a dramless tlc drive).
The samgsung software just shrinks the partitions, nothing special. Have free space on your disk will do the same thing as trim is used.
Just 10% of the capacity?
Yes, and that's transparent to you. Even if you fill the drive, those 10% extra will still exist behind the curtains.
Lenovo N23 Yoga
There are like 3 things that you could name overprovisioning
1) Spear NAND cells.
2) The cut RAW to User NAND Capacity by the SSD controller, like 2048GB to 2000GB, that NAND is used for TRIM and so on.
3) The unformatted space, that you just leave on your initialized SSD, beside the formatted partitions, that NAND is used for TRIM and so on.
But the SSD will still use the free formatted space left on the SSD partition, for TRIM, pSLC bufor (well it depends) and wear leveling.
It's all depend on why are you wanting to do it... What's the purpose?
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
Simply to extend my SSD's lifespan as much as possible.
Then just don't fill it up past 80%, it won't matter much, if it's just empty space on partition, or unformatted space beside the formatted partitions.
Today good SSD have strong error correction algorithms, good wear leveling, and some have data refresh function to refresh the old data, before it's gone...
Just don't leave your SSD without power for months (especially somwere hot), don't cool the NAND when its operating, and don't buy cheap QLC or TLC drives.  Buy good TLC, or MLC SSD, or optane
Just have good PSU with low ripple, it's rather hard to kill the NAND in good TLC SSD. It's more likely that the controller will just die.
do you have lots of writes to the SSD?
If it's important server, that just have RAID 1 from the identical SSD.
EXTERNAL
HDD/SSD :
