I need white peripherals for my PC
Solved by Samdb,
If you want a mechanical keyboard, which I would advise you could go with the Ducky Shine 3 white edition and pick yourself a set of white keycaps from WASD.
http://www.wasdkeyboards.com/index.php/products/keycap-set.html
Alternatively, if you want to use Apple peripherals, the keyboard in particular, you could use this tool. But before you buy I recommend borrowing your friends keyboard to ensure that it will work on your PC.
