New Lian Li Lancool 3 Mesh Case ordered.
Solved by JCMikulak,
Update: I installed the Arctic Liquid Freezer II 420 AIO up top...like Gamers Nexus mentioned in their review, the rear exhaust fan has to come out and there's no room for it. Also, in the case's stock front fan bracket configuration from the factory, the 420 will not fit. It won't let the fan bracket completely close. I took the bracket out, turned it around, and reinstalled it, and that let the radiator fit :). Just don't forget to route and plug in the motherboard's EPS power cables before installing the radiator...
