PSU and Monitor Mains cable not going in fully
Solved by Wohaaa,
1 minute ago, dani.petro said:They are quite tight. The monitor one specially is extra tight and needs quite a bit of elbow grease to break loose and pull out. The PSU is also tight but not as much as the monitor.
Then you have absolutely nothing to worry about, this is normal
Featured Topics
2
9
CDR_Xavier ·
Posted in Build Logs1 -
McBeth1087 ·
Posted in New Builds and Planning11 -
7
NamelessUser ·
Posted in Troubleshooting1 -
HereWeGo ·
Posted in Power Supplies3
