rate my cable management
Go to solution Solved by aisle9,
See that wall off to the right side of your setup? See how the table legs run parallel to it? With a little bit more effort and a power strip (which you should be using anyway--those multi-tap wall connectors will burn your house down), you could easily run all of your cables across the back of the table, down one of those legs and to the PC or the wall. On a scale of one to ten, I give you an "incomplete".
2/10. Stretch out your feet and it can easily get caught in that loop of cables.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
6 hours ago, Novasandfriends said:
-0/10. No PSU cables are plugged in. Obnoxious blue USB3.0 FP connector sitting out in the open. Rainbow skittles RP connectors are not plugged in. Rear exhaust is not plugged in. +1 because of a Haich Pea SSD.
Weird flex but okay.
