How to fix color streaking
Solved by SteveKaboom,
Thank you for your help! I was able to figure out what the problem was, so I wanted to share in case anyone else runs into this same issue. LG gaming monitors have a response time setting with Off, Normal, Fast, and Faster as your options. Looking into this, I found out that the Faster option is only recommended for response times above 120Hz. With that setting on however, anytime the response time drops too low, it causes problems like the one I was having. Once I changed the setting, it went away entirely. So just as a word of caution to anyone with an LG gaming monitor, that response time setting may cause trails or shadows. If that's the case, just turn it back to Fast.
