PC Crashes when gaming - I HAVE TRIED EVERYTHING! pLZ hELP :)
Solved by kikilokiki,
Thank you all so much for you help.
DigitalGoat : I tried your suggestion and I repasted the card as well as put 1 fan underneath it blowing air directly to the card. This helped to keep the temp down by about 15 degrees and COD ran super fine hovering at 70C which is quite excellent.
I am going to keep the power a bit lower since it didn't like arriving at 80C but I can at least run the card now at 90% power and it not carshing.
Again, thank you all for your help.
