How long do I need to wait so I can charge my phone again
The rice suggestions are stupid.
If water got INTO the phone, no amount of rice will absorb the humidity from inside the phone. The solution is to RIGHT AWAY turn OFF the phone and IF YOU can disconnect battery and then you (or a service place) must open it up and clean the insides.
Water is conductive, unless it's distilled water ... so water and impurities in the water can form "bridges", connections between two electrical points or traces inside the phone, on the circuit board, and can cause bad things over time... and while you keep the phone under rice, the battery of the phone is still connected to the circuit and moves electricity through the chips and the water and impurities can do damage.
Rice on itself absorbs humidity, but not fast enough to be a solution to "water got INTO my device".
You'd be more effective with a bunch of those SILICA GEL baggies you find with shoes and various devices - those absorb humidity much faster but the device would still have to be opened and cleaned IF water got INTO the phone.
Considering it fell in water for such a short time, and you cleaned it right away, and they claim the phone is water resistant (meaning it's quite hard for water to get INTO the phone) then simple cleaning of the parts that got exposed to water with a cleaning substance (isopropyl alcohol, wipes for cleaning your glasses or monitors - they usually have isopropyl alcohol in them) would be enough.
28 minutes ago, Zastonish said:I would not want to if it wasn't covered in piss I still need to eat rice
Are you a troll or stupid? You decide to not use a potential solution that saves you few hundred dollars because you need to eat half a dollar worth of rice?
