Samsung odessay G7 27 inch VS LG gp850-b
Gamerboy1996
This will be my first gaming monitor, i would like to know if it's worth 200€ more on getting samsung?
The only thing i am worried is 1000R curve on samsung... is the picture quality that much different?
It all comes down to personal preference imo.
Either you like VA contrast and curve or something else for that extra cost.
I edit my posts more often than not
For most people the LG one is probably the better choice. The Samsung can be a good option if you can get used to the curve. But it's really down to preference. Both are good performers.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
that's the thing, for 25 years i never had a gaming monitor, all i saw was bad laptop screen, so idk, i like curved monitors, but 1000R seems too much vor me, (i can't see it in real life, coz in my country there are no good monitors in stores...)
Thanks😊
i also think about Dell s2722DGM but it doesn't have G-sync, but i have AMD gpu, maybe will buy nvidia new gen gpu's when they come out
It all comes to personal preference and or price. Also yeah, by the latest "leaks" the nVidia RTX 4000 cards are arriving early.
thanks
