3 radiators fit in case
StormBreakes
I have some problem to fit 3 radiators in my case, top 360 mm front 360 mm.
2 x 360 mm radiators
1 x 240 mm radiator
Plan is to mount 2 in front on each other and 1 top.
what’s is the best solution?
3 minutes ago, RONOTHAN## said:
Stacking rads doesn't help performance. May I ask why you're trying to do that and what case you're trying to put stuff in?
I have 2 GPU With closed loops water cooling and 1 CPU water cooling.
Phanteks Eclipse P500A DRGB
Thats wild, got some photos of the set up?
I cant see any other way in that case, not even on the bottom because of the PSU shroud, gotta be 2x360 at the front and the 240 at the top. are your GPUs in the regular horizontal position?
