I still have no idea what Im doing with python, this script was made in about 2 hours of me learning python and reading through RPi.GPIO documentation.
Its going to run on boot with rc.local, once i can set it up. Other than that it runs fine.
import RPi.GPIO as GPIO
import time
from gpiozero import CPUTemperature
cpuTEMP = CPUTemperature()
power = 12
tempHIGH = 26
loop = 0
GPIO.setmode(GPIO.BCM)
GPIO.setup(power, GPIO.OUT)
GPIO.setup(tempHIGH, GPIO.OUT)
while loop == 0:
    GPIO.output(power, GPIO.HIGH)
    time.sleep(.2)
    GPIO.output(power, GPIO.LOW)
    tempNOW = (cpuTEMP.temperature)
    if tempNOW >= 80:
        GPIO.output(tempHIGH, GPIO.HIGH)
    else:
        GPIO.output(tempHIGH, GPIO.LOW)
    time.sleep(.8)
Is there anything super stupid I did?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
as long as it works it's good enough.
i would probably say to increase the sleep time a bit more, given you at least have somewhat of a heatsink the temperature will be a very slow changing process, so about 5 seconds wouldnt be too extreme IMO.
THe sleep time is short to facilitate the blinking of one LED, thus the sleep times being short
And my heatsink is small enought that when i have a heavy load, the temperature can drop ~10c in less than a second
7 minutes ago, Pandur said:
You never change the loop variable. So your while statement can be "while True:" and you can remove the loop variable.
thats a good point
Bios database
prior build:
