  1. ALWAYS list your complete system details.
  2. You can take a screenshot of a window by holding ALT then pressing PRTSCR
  3. Windows Task Manager is not exactly a reliable tool to check things like that.
https://linustechtips.com/topic/1431864-xmp-not-doing-anything/#findComment-15401191
Thanks for the help.....
https://linustechtips.com/topic/1431864-xmp-not-doing-anything/#findComment-15401195
You are welcome. This is the best anyone can do with how little you have in your post, other than giving you 30 possibilities why it doesnt work and turning this place into webmd of tech forums. You can check memory speed more reliably via cpuz (in the open tab of CPUZ I provided you with below in a screenshot)image.thumb.png.00d108aa2096d9b15a4ab098940346c6.png
https://linustechtips.com/topic/1431864-xmp-not-doing-anything/#findComment-15401199
Under-statement of the year.  I was actually shocked to find task manager correctly identified the speed of my RAM recently, I'd say it more often gets it wrong than right.
https://linustechtips.com/topic/1431864-xmp-not-doing-anything/#findComment-15401213
