Is XMP profile enabling for 2666MHz safe and worth it?? Now it runs on 2133MHz without XMP enabled
Solved by YoungBlade,
9 minutes ago, Levent said:Might as well go for 3200mhz XMP profile first, if it doesnt work try selecting 2666mhz manually.
It will not work as memory overclocking is not supported for B460 boards. The OP will have to turn on XMP and then manually set the clock speed to DDR4-2666, as that's the max official speed for the 10400F.
