I am searching for parts that i will buy to build a pc. When i tried to search for a pc case, i noticed that most of the producers of cases make the side window where you can see all your components is usually on the left side (if you are looking from the front). I was wondering whether there are any full tower cases which have the window on the other side. The maximum cost for the case is $300.
Thanks for your suggestions
https://linustechtips.com/topic/143045-reverse-pc-case/
Why would you want a window on that side, that's where all the cable are.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1909431
why would you want to see all the ugly cases from the other side....
here you go
http://www.corsair.com/en/graphite-series
Specs
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1909434
Silverstone FT02/RV02/TJ11
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1909657
Silverstone ft02
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1910645
Sorry if i did not put my wording right. I wanted the case to be a miror image of normal cases. For those people that gave me some great choices thanks. I will look further into the numerous choices you have given me and i will choose what will suit me best.
Thank again
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1910657
FT/RV02 TJ11 would all be good cases.
Or if you want to take the difficult route like I did, take a look of the Cosmos II build in my signature.
https://linustechtips.com/topic/143045-reverse-pc-case/#findComment-1927301
