Thermal paste recomendation for i5-12400 + NHD14?
Solved by Zando_,
Arctic MX-4, Noctua NT-H1 and NT-H2 are all good value picks and H2 is the best peforming out of them I believe. I think Thermal Grizzly Kryonaut still has the lead over those for performance but it costs a lot more. Difference is a few C between all of them though, so unless you're right on the limit (you will not be near the limit of your cooling with that chip and cooler combo) it's sort of a non-issue.
