looking for a decent colour accurate monitor
Kinn_Slayer
I do graphic design and UI. I wanna upgrade from my laptop screen( omen15) to a 4k monitor with good colour accuracy in around $400 -$500.
I don't know much about monitors, so it would be great if you guys can help me
PS. If the above resolution is not possible in my budget then I please tell me some 1440p monitors
Thanks🙂
Thanks🙂
If you absolutely need colour accuracy then its gonna cost as pre-calibrated monitors come at a price.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Thanks🙂
for around that price, i'd pay a bit more for the u2720q over the pd2700 for 4k - this is what i'd recommend out of everything on this list
for 1440p i'd recommend the MSI MAG274QRF-QD, it's marketed as a gaming monitor but it is just that good for 400usd
for pure colorwork at 400usd and if all you care about is color accuracy, gray scale and LUT, my recommendation would be the BENQ SW240 at 400usd
4k version of the SW240 cost 800usd
https://www.bhphotovideo.com/c/product/1547779-REG/dell_27_u2720q_ultrasharp_4k.html
https://www.bhphotovideo.com/c/product/1397520-REG/benq_sw240_24_ips_wuxga.html
https://www.bhphotovideo.com/c/product/1607537-REG/msi_optix_mag274qrf_qd_27_monitor.html
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
