Pc shutdown & restart twice after turning on, then works fine.
Solved by Case maker,
6 hours ago, Ebony Falcon said:I never looked deeper into it but every pc I have had does this to set up xmp
remove the xmp and leave it at default and see if it carry’s on Maby ?
Every settings is default. I don't really overclock or tinker with the bios setting. Its just a minor inconvenience that I have to reset time everyday. I guess some problems are beyond our control. Hey man, thank you for your time & help. I really appreciate.
