I am not sure
Money can be saved by just not buying only from that one site. No need to buy thermal paste. Coolers come with it. White PSU with white cables. PSU is more than you need, but would allow for a 6800xt/3070 ti later if wanted. AIO is Corsair, and will play better with iCue than others. Case is much better than the 510 while not being much more expensive. Some budget left over for spare fans if you wanted to swap the black ones that come with the case out for white.
CPU: AMD Ryzen 7 3800X 3.9 GHz 8-Core Processor (Purchased For €0.00)
CPU Cooler: Corsair iCUE H100i ELITE CAPELLIX 75 CFM Liquid CPU Cooler (€129.90 @ Amazon Netherlands)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard (€166.82 @ Amazon Netherlands)
Memory: Corsair Vengeance RGB Pro SL 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (€154.97 @ Amazon Netherlands)
Video Card: Gigabyte Radeon RX 5500 XT 4 GB OC Video Card (Purchased For €0.00)
Case: Corsair 275R Airflow ATX Mid Tower Case (€79.90 @ Amazon Netherlands)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€83.85 @ Megekko)
Total: €615.44
Generated by PCPartPicker 2022-04-19 19:39 CEST+0200
Edit: I see your list above. The 220T is 20 Euros cheaper elsewhere btw.
https://nl.pcpartpicker.com/product/wj4BD3/corsair-icue-220t-rgb-atx-mid-tower-case-cc-9011174-ww
