Swap to Titanium Given Fuel Prices
First, if you're going to compare PSU efficiency you should ignore the 80+ system and instead use Cybenetics.
Generally, a Cybenetics Titanium rated PSU performs about 92% efficient while gold is 88% (115V). Though, your RM1000x is actually a platinum PSU with overall 91% efficiency on 240V. A Titanium Corsair AX1600i is overall 94% efficient on 240V
At full load your system can consume about 400W (100W from the CPU, 300W from the GPU.
I don't know anything about UK electricity prices, so in this example I'll assume it'll rise to 40 p /kWh.
For every hour of full system load, you'd save:
400w/1kw * (1/0.91 - 1/0.94) * 40p = 0.56p/hour.
So if you run your pc at full load everyday for 3h/day you'd only save £6.14.
I think you already know how expensive titanium PSUs are too.
TLDR - Your PSU is already very efficient and upgrading it is probably not a good investment.
