NPM and Google Drive Issue
Go to solution Solved by Eigenvektor,
9 hours ago, Stentorian said:
I am aware of the alternatives such as Git and I use GitHub for a majority of my projects.
Can you configure Google drive to exclude files/directories? If so, you'd probably want to exclude everything that's also excluded in the .gitignore file.
Alternatively you could create a Git repo on a private server (local or remote) and use that as a backup. Or alternatively compress the source code, then put the .zip on Google drive. Could probably be scripted to automate it to some level.
Hi there.
So I'm currently experiencing some issues with Google Drive and NPM. I am using the new Google Drive on Windows (if I remember correctly, used to be called Google Filestream).
The issue basically involves the fact that when I do npm install in a Node.JS directory, it tells me that the <PROJECT DIRECTORY>/node_modules folder doesn't exist. Using the same project files and package.json in my local Downloads folder worked absolutely fine and installed everything like it was supposed to.
The full error is as below:
npm ERR! code ENOTDIR
npm ERR! syscall mkdir
npm ERR! path G:\My Drive\Coding\1. Node\1. Discord.JS\SleepBot\node_modules
npm ERR! errno -4052
npm ERR! ENOTDIR: not a directory, mkdir 'G:\My Drive\Coding\1. Node\1. Discord.JS\SleepBot\node_modules'
npm ERR! A complete log of this run can be found in:
npm ERR!     C:\Users\stent\AppData\Local\npm-cache\_logs\2022-03-13T17_06_01_171Z-debug.log
The log file mentioned above has been attached to this post.
And my package.json:
  "name": "sleepbot",
  "version": "1.0.0",
  "description": "A custom bot to fix the brat's sleep schedule",
  "main": "app.js",
  "scripts": {
    "test": "echo \"Error: no test specified\" && exit 1"
  "keywords": [
    "sleepbot"
  "author": "Stentorian",
  "license": "ISC",
  "dependencies": {
    "ascii-table": "^0.0.9",
    "chalk": "^4.1.2",
    "cron": "^1.8.2",
    "discord.js": "^13.6.0",
    "fs": "^0.0.1-security",
    "moment": "^2.29.1",
    "ms": "^2.1.3"
If anyone could help, that'd be great!
PC:
Motherboard: MSI Z390-A PRO
CPU: Intel Core i7-9700K @ 3.60GHz
Memory: 32GB (4x8GB) Corsair Vengeance
Graphics Card: NVIDIA GeForce RTX 3060 Ti
Boot: Crucial P3 2TB M.2
SSD: Crucial BX500 1TB SSD
SSD: Crucial P2 500GB M.2
PSU: Gigabyte P750GM 750W
Case: IONZ KZ10
"Server":
Motherboard: X99 RSA mATX (eBay special)
CPU: Intel Xeon E5-2680 v4 @ 2.4GHz
Memory: 64GB (2x32GB) Dataram ECC DDR4
Graphics Card: NVIDIA Quadro P2000
Boot: Kingston NV3 1TB M.2
PSU: Corsair CX550
Case: Fractal Design Core 1000
OS: Proxmox Virtual Environment
Other Gear:
Phone: Google Pixel 6 (128GB)
Watch: Google Pixel Watch
Headphones: SteelSeries Arctis 3
Microphone: Blue Snowball Ice
Speakers: Creative T100
Car: 2010 Mazda 3 Takuya - 1.6L Petrol 103bhp
https://linustechtips.com/topic/1417879-npm-and-google-drive-issue/
Having Node.js projects on a synchronized folder is a bad idea, especially when you can't make it exclude the node_modules folder (which is the case for Google Drive). It causes issues like this, and the folder occupies a large amount of space. The best way to resolve this is to simply use something else (ideally not using a sync'd folder). There are a lot of posts online detailing how bad of an idea this is
If you want to share code between different machines or dual boot, use something that was designed for this, e.g. Git in the form of GitHub or GitLab.
I am aware of the alternatives such as Git and I use GitHub for a majority of my projects. This is just as a backup for anything that I haven't committed and I have a lot of projects that although GitHub has private projects, I don't want to put on GitHub and afterall, I don't pay for 100GB Google Drive for nothing.
PC:
Case: IONZ KZ10
"Server":
PSU: Corsair CX550
Other Gear:
This is the issue. They used to have that as a feature, but then removed the ability to exclude certain folders. I kind of wish they'd incorporate something like a .gitignore file for Google Drive, but it's Google and asking for something like that is like asking a bank for free money.
I will have a look at the automated .zip solution. Thanks for your help!
PC:
Case: IONZ KZ10
"Server":
PSU: Corsair CX550
Other Gear:
