Does it matter if an eye terminal is slightly larger than the battery terminal I am connecting it to?
Solved by mr moose,
The battery has a spade terminal, it is not supposed to have a bolt go through it. Crimp a female spade terminal to your wire and simply slide it on.
Featured Topics
Magnumenforce ·
Posted in Phones and Tablets0 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
3
8
