Posted February 14, 2022 I’ve changed resolution settings and even whether it’s display 1 or 2 and nothing works. It’s a Red Devil Radeon 5700XT. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2022 use DDU to uninstall drivers in safe mode and try again? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2022 are the other displays detected in windows? Are they also able to connect via HDMI? How does the system act with one display plugged in at a time? I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2022 Author 1 hour ago, Fasauceome said: are the other displays detected in windows? Are they also able to connect via HDMI? How does the system act with one display plugged in at a time? It acts completely normal, my guess now is that it might be driver issues maybe? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2022 1 hour ago, BollyWood401 said: It acts completely normal, my guess now is that it might be driver issues maybe? you made sure each individual port works right? If all the ports on the GPU work properly it probably is a driver issue, or some weird configuration problem with the windows display settings I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
