Longs story short, I need help. Im trying to make a "play again" button when the game says "Game Over", but I do not know how. Can anyone help? Code also attached to this post. You can edit the code all you like. The game is also attached to the attachments. Thank you.
package neo.kaarmepeli;
import java.awt.Color;
import java.awt.Dimension;
import java.awt.Font;
import java.awt.FontMetrics;
import java.awt.Graphics;
import java.awt.Image;
import java.awt.Toolkit;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.KeyAdapter;
import java.awt.event.KeyEvent;
import javax.swing.ImageIcon;
import javax.swing.JPanel;
import javax.swing.Timer;
public class Board extends JPanel implements ActionListener {
    private final int B_WIDTH = 300;
    private final int B_HEIGHT = 300;
    private final int DOT_SIZE = 10;
    private final int ALL_DOTS = 900;
    private final int RAND_POS = 29;
    private final int DELAY = 140;
    private final int x[] = new int[ALL_DOTS];
    private final int y[] = new int[ALL_DOTS];
    private int dots;
    private int apple_x;
    private int apple_y;
    private boolean leftDirection = false;
    private boolean rightDirection = true;
    private boolean upDirection = false;
    private boolean downDirection = false;
    private boolean inGame = true;
    private Timer timer;
    private Image ball;
    private Image apple;
    private Image head;
    public Board() {
        initBoard();
    private void initBoard() {
        addKeyListener(new TAdapter());
        setBackground(Color.black);
        setFocusable(true);
        setPreferredSize(new Dimension(B_WIDTH, B_HEIGHT));
        loadImages();
        initGame();
    private void loadImages() {
        ImageIcon iid = new ImageIcon("src/resources/dot.png");
        ball = iid.getImage();
        ImageIcon iia = new ImageIcon("src/resources/apple.png");
        apple = iia.getImage();
        ImageIcon iih = new ImageIcon("src/resources/head.png");
        head = iih.getImage();
    private void initGame() {
        dots = 3;
        for (int z = 0; z < dots; z++) {
            x[z] = 50 - z * 10;
            y[z] = 50;
        locateApple();
        timer = new Timer(DELAY, this);
        timer.start();
    @Override
    public void paintComponent(Graphics g) {
        super.paintComponent(g);
        doDrawing(g);
    private void doDrawing(Graphics g) {
        if (inGame) {
            g.drawImage(apple, apple_x, apple_y, this);
                if (z == 0) {
                    g.drawImage(head, x[z], y[z], this);
                } else {
                    g.drawImage(ball, x[z], y[z], this);
            Toolkit.getDefaultToolkit().sync();
        } else {
            gameOver(g);
    private void gameOver(Graphics g) {
        String msg = "Game Over";
        Font small = new Font("Helvetica", Font.BOLD, 14);
        FontMetrics metr = getFontMetrics(small);
        g.setColor(Color.white);
        g.setFont(small);
        g.drawString(msg, (B_WIDTH - metr.stringWidth(msg)) / 2, B_HEIGHT / 2);
    private void checkApple() {
        if ((x[0] == apple_x) && (y[0] == apple_y)) {
            dots++;
            locateApple();
    private void move() {
        for (int z = dots; z > 0; z--) {
            x[z] = x[(z - 1)];
            y[z] = y[(z - 1)];
        if (leftDirection) {
            x[0] -= DOT_SIZE;
        if (rightDirection) {
            x[0] += DOT_SIZE;
        if (upDirection) {
            y[0] -= DOT_SIZE;
        if (downDirection) {
            y[0] += DOT_SIZE;
    private void checkCollision() {
            if ((z > 4) && (x[0] == x[z]) && (y[0] == y[z])) {
                inGame = false;
        if (y[0] >= B_HEIGHT) {
            inGame = false;
        if (y[0] < 0) {
            inGame = false;
        if (x[0] >= B_WIDTH) {
            inGame = false;
        if (x[0] < 0) {
            inGame = false;
        if (!inGame) {
            timer.stop();
    private void locateApple() {
        int r = (int) (Math.random() * RAND_POS);
        apple_x = ((r * DOT_SIZE));
        apple_y = ((r * DOT_SIZE));
    @Override
    public void actionPerformed(ActionEvent e) {
        if (inGame) {
            checkApple();
            checkCollision();
            move();
        repaint();
    private class TAdapter extends KeyAdapter {
        @Override
        public void keyPressed(KeyEvent e) {
            int key = e.getKeyCode();
            if ((key == KeyEvent.VK_LEFT) && (!rightDirection)) {
                leftDirection = true;
            if ((key == KeyEvent.VK_RIGHT) && (!leftDirection)) {
            if ((key == KeyEvent.VK_UP) && (!downDirection)) {
                upDirection = true;
                rightDirection = false;
            if ((key == KeyEvent.VK_DOWN) && (!upDirection)) {
                downDirection = true;
import java.awt.EventQueue;
import javax.swing.JFrame;
public class Snake extends JFrame {
    public Snake() {
        initUI();
    private void initUI() {
        add(new Board());
        setResizable(false);
        pack();
        setTitle("Snake");
        setLocationRelativeTo(null);
        setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
    public static void main(String[] args) {
        EventQueue.invokeLater(() -> {
            JFrame ex = new Snake();
            ex.setVisible(true);
Board.java Snake.java matopeli.rar
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1411463-help-me-with-my-java-project/
Can you ask a more specific question?
Unfortunately not a lot of people are going to download and try to understand your project, myself included.
 If you break down what you really want, it will be easier to help you
You can use the Java JButton class to create buttons. Something like (More info: AWT Button Class (tutorialspoint.com)
JButton replayButton = new JButton("Play Again");
replayButton.addActionListener(new ActionListener() {
		// Add button click logic here
Panel buttonPanel = new Panel();
buttonPanel.add(replayButton);
More likely, you're looking for a button feature within the Java Graphics. You can create a more customized button and detect click within shapes like this:
Shape replayButton = new Rectangle2D.Double(100, 100, 100, 100);
addMouseListener(new MouseAdapter() {
  @Override
  public void mouseClicked(MouseEvent me) {
    super.mouseClicked(me);
    // Check if mouse is clicked within shape
    if (replayButton.contains(me.getPoint())) {
		// Add code for button click here
