cpu cooler removal/new cooler choice help
Ghosted Muzik
Go to solution Solved by MistahHaskins,
2 minutes ago, Ghosted Muzik said:
ok so like i could run cinebench on a loop for a bit then try to remove?
Anything that heats the paste, play a game or what many do is run Aid64, Cinebench R20 or Prime95, pretty much anything that will heat up the CPU the fastest.
On my 5600x I am using Cooler Masters' Hyper 212 BE Non-RGB cooler, runs around $40ish bucks and keeps it at around mid 60s, to low 70s in games
so i have on this newly built pc a ryzen 5600x on a stock amd cooler. the time i had to pull the cooler off to fit the 2nd kit of ram it pulled the cpu out with it, is there any tricks to prevent that?
also now that i have the cpu on auto overclock it hits high 80C on temps so im looking for a decent ait cooler that isnt too overkill, also rgb wouldnt hurt
also next step will be chassis fans i can control
long time viewer on youtube but first post here as i figured yall be smarter then my friends
Heat the CPU up first.
Twist the cooler, don't pull straight up.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Gaming Rig:
CPU: Ryzen 5 5600x  | CPU Cooler: Cooler Master Hyper 212 BE  |  GPU: ZOTAC GeForce RTX 3060 Twin Edge OC  | RAM: Corsair Vengeance LPX 32GB DDR4 3200mhz  |  Motherboard: Gigabyte B450M DS3H V2  |  Storage:  WD Blue SN550 1TB NVMe M.2 SSD  |  Case:  Corsair 4000D Airflow  |  Power Supply: Corsair CX650w Bronze Series
awesome, btw is that oc? granted i mainly play minecraft and 7 days due to only a 2gb 960 as my gpu but before the auto oc was turned on i kept a solid 62-66c with stock cooler but now im in the 70s
This is without an OC but with PBO on so sorta
Gaming Rig:
whats PBO? sorry still learning
Precision Boost Overdrive. It is an opportunistic automated overclocking mechanism found in various AMD processors that pushes the system power budget beyond its rated specifications in order to allow Precision Boost to act more aggressively and achieve higher performance
Gaming Rig:
