Help me decide between the Beyerdynamics DT770/880/990 and ohm variants to add to HD6XX and ATH m40x collection, out of an O2 amp
Solved by rice guru,
Unfortunately the 880 is not really semi closed as advertised being an owner of all 3 DTs the 990 premium is more semi closed than an 880. They are fairly comfortable in the long Term. If you want something super different than what you have the 990 is decent and will be different but if you ask me which is best the 880 is my vote. 990s bass are great through for gunshots and explosions. And staging wise both 880 and 990 are very similar. For your gear yes I personally would stick to the 250 ohm and probably a slight EQ for the 990. Alternatively the beyerdynamoc tygr exists and is very easy to drive and has the benefits of the 990 without too much treble murder.
