Need Help! DDR4 2666 on DDR4 1866 Motherboard
Solved by mariushm,
16 minutes ago, FRSHPRNCFBLR said:Are you sure it supports DDR4? 1866 is a typical DDR3(L) speed, while 2133 and upwards would be DDR4 speeds.
Specs list it as DDR4, up to 1866 MT/s : https://support.hp.com/in-en/document/c05240287
Yeah, should be able to get 2133/2400/2666 Mhz SO-DIMM sticks and they should run just fine. Though how much performance increase or how useful it would be with that processor, it's another story.
