1 hour ago, Nominatid said:
I know I have to find it in BIOS and mainly it is in a memory tab or just in an advanced tab. And I cannot find either tab.
I don't think DELL's OEM Mobo have that feature.
Refresh before you reply
https://linustechtips.com/topic/1407634-i-need-help-with-xmp/#findComment-15232931
I think it just uses the fastest speed available that came with the system (OEM installed)
Edit:
If you upgrade you have to at least match 2666 MHz or above i would just get whatever DDR4 ram is the cheapest beyond this point anything with lower speeds DDR4 should be obsolete by now.. (obv bottleneck)
https://linustechtips.com/topic/1407634-i-need-help-with-xmp/#findComment-15232943
