Power outage during file transfer on HHDS
Solved by Electronics Wizardy,
4 minutes ago, Pc6777 said:But I'm more worried about the unrelated files on the discs, beacause I know with smr drives the drives rewrite existing data to write new data but I was using only cmr drives so I'm less worried, but still a little paranoid, like I said worst case I have backups but I don't want to have to pull my stuff off optical media unless I have to
You really don't know unless you have another checksum or backup to compare to.
But HDDs(even smr) are generally good at storing data even if there is a power loss, and only data that is being copied to the drive is at risk. I have had many a system lose power and have no noticable data loss or corruption.
