Using home cinema set speakers as pc speakers
WinnieDePoeh
Hi all,
So I have this Samsung home cinema set my dad bought around 2013. The receiver, a Samsung HT-E5500 broke a few years ago and the speakers are useless without the receiver because of the peculiar connectors the speakercables have. I own a set of pc speakers, they are not bad, but also not that great. So I thought maybe I can use my old 5.1 Samsung cinema set speakers as pc speakers. The cable and the connectors of the speakers look like this: https://imgur.com/a/jFTya4g all the speakers come with their own cable with their own connector color. They all go into the cinema set which looks like this: https://imgur.com/a8ZiWjM. The name of the speaker set is ps-es4-1.
I thought that maybe there is some kind of adapter or other thing I can use to transmit the speaker signal into my pc, but it's harder to find information about it than i thought.
Do you guys have ideas?
Thanks in advance
They look like passive speakers to me, so you'll need an amplifier instead of going straight to the PC.  Secondly the back of that unit says 3 Ohm, while nowadays from memory I mostly see 4-8 Ohm. I'm not sure if that they'll play completely nice with each other in the case of that mismatch.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
There is nothing that say's you couldn't get a second hand receiver and clip those plugs off the end at which point the only proprietary piece was the plug on the old and now dead receiver.  After cutting those off it's just speaker wire that can be easily connected to a standard pole.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
yea those 3ohm speakers on a 8ohm avr most likely will be bad...maybe a 4ohm avr will be better suited. (im betting if you throw a meter on them it will say 4 or 4.5ohm)
this is what i got from a site about using 3ohm on a higher ohm
"If the receiver was designed to use a 6 to 8 Ohm speaker, then changing the speaker to a 3 Ohm type will demand more current from the audio amplifier. This might damage the amplifier or cause the sound to be distorted for lack of proper current through the speaker. "
