Need info about PCIe
Solved by Sihastru,
PCIe 3.0 cards/slots are backwards compatible with PCIe 2.0.
If I connect PCIe 3.0 16x graphic card to 2.0 16x slot, is it going to work on 3.0 8x?
A PCIe 3.0 16x card in a PCIe 2.0 16x slot will work @PCIe 2.0 16x. The bandwidth of PCIe 2.0 16x is almost the same as the bandwidth of PCIe 3.0 8x.
If so, how are 2 graphics 3.0 gonna work (4x/4x ?) in crossfire on 2.0 mobo that work on 8x/8x in crossfire?
Two PCIe 3.0 16x cards that are each inserted in PCIe 2.0 8x slots will work @PCIe 2.0 8x. Again, bandwidth of a PCIe 2.0 8x is almost the same as the bandwidth of PCIe 3.0 4x.
