2 minutes ago, Electronics Wizardy said:
Try setting a static IP, and see if that works.
What are the system specs? Truenas can be kinda picky about hardware.
cpu: 2500k
MB: Asus P8B75
ram: 16gbs
120gb ssd (os)
how would i set a static IP?
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15135194
22 minutes ago, jhogan93 said:
cpu: 2500k
MB: Asus P8B75
ram: 16gbs
120gb ssd (os)
use the 1 option for configure network interfaces to give it a static ip.
But good chance the nic isn't support in truenas.
Did you try something like unraid?
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15135201
  • 4 months later...
On 12/4/2021 at 3:58 AM, _hitman_ said:
Truenas CORE is notoriously bad with realtek nics. TrueNAS scale is better option with realtek nics.
CORE and SCALE have the same problem, no Realtek support.  It's out there, but it seems a Herculean task to make it work.
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15359796
Scale is working with realtek with no problems, it is based on debian.
Core/Freebsd does not like rtl chipsets.
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15360597
Yes Scale is based on Debian, but its still its own stripped down version. Scale was missing support for a lot of Realtek controllers until a few months ago.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15363477
You can just install Realtek drivers? My motherboard had a Realtek NIC on it that wasn't supported, downloaded the drivers, loaded them, and it worked.  These are my personal notes from when I loaded the drivers for my TrueNAS build, if it helps anyone (1.96.04 were the version of drivers I loaded)
Copy version 1.96.04 to /boot/kernel
    - cp if_re.ko /boot/kernel
    - chown root:wheel /boot/kernel/if_re.ko  (Change owner)
    - chmod 555 /boot/kernel/if_re.ko   (Change permissions)
Edit /boot/loader.conf To include if_re_load="YES" This line can be anywhere. Must use vi.
    - vi /boot/loader.conf
After doing this, my Realtek NIC just worked as expected. Don't get me wrong, it's easier to have a supported NIC, but it's not game over if your NIC isn't supported.
https://linustechtips.com/topic/1393030-first-nas-trunas-etc/#findComment-15364266
