Virtual Machine
Solved by RONOTHAN##,
11 minutes ago, Space646 said:Yes, windows. I shouldn't have any hardware liminations, I use a ryzen 3700x, 48GB ram. I also heard about VMware. What do you think is better?
If you're on Windows, the two big options are Hyper-V and VirtualBox. Both of them have their pros and cons. If you're gonna use Windows in a VM, I'd use Hyper-V. If you're gonna use Linux, use VirtualBox.
That said, Windows isn't a good virtualization host. If you are doing anything more than spinning up a quick VM to test something, you should probably transition your host machine to Linux and use Redhat KVM and QEMU. Something like VirtManager is a good way to manage everything, and has a ton more features in comparison to anything on Windows.
