Unraid in VirtualBox not working, please help!
Heres the steps
Made a VHD in Disk Management called UNRAID-USB-VHD.vhd (this can be small, even just 1GB)
I downloaded UnRAID Flash Creator and created a bootable usb of the latest UnRAID 6.9.2
I ran the make-bootable.bat script just to be sure it was bootable.
I copied all the files from the USB key to UNRAID-USB-VHD.vhd. Ejected the Virtual disk.
Created the VM as type Linux / Other Linux (64-bit)
Attached the .VHD as the primary disk and attached the USB, changed the USB controller and started UnRAID.
If youre using USB 2.0 ports on your computer, then you need to set the USB Controller to 2.0
Edit: I think i also renamed the virtual disk to UNRAID temporarily to run the make-bootable script on that also, and renamed it back
