EVGA 3070 FTW3 Fan noise
16 minutes ago, Lemad said:Really appreciate the genuine response. I guess it's just difficult for me to accept considering I just bought this and just want to be certain that noise will not result in further damage/problems down the road and if it will I'd like to return it if not I'm fine with it. Thanks!
I'll agree it's rather annoying. As I said I gave up and just set my cards so the fans spin at a low speed all the time. You could do the opposite and raise the minimum turn on speed if you prefer. So they are off most of the time. They really are pretty quiet so even at the 30% I'm using it's not noticeable in my opinion.
Even if you had an issue, EVGA is known for standing behind their stuff. I've dealt with their customer service before, I have nothing but good things to say. My 1070 FTW card is one that needed thermal pad mods, the whole thing was excellent. (If you couldn't tell as I've continued you buy EVGA cards) The only cards I have that are small form factor (cards for cases EVGA doesn't make).
You can always email EVGA support directly and see what they say if that would make you feel better.
