Hello, I’m having problems as well with dd-wrt,
I have turned my virgin media hub into a modem and connected my WRT3200ACM to use as a router for WiFi/lan etc, I have done everything to make it work as it should and want to install dd-wrt, so I can use ipvanish with it
I have followed all links provided by linksys and downloaded the relevant file to update the firmware but when doing this I get no internet afterwards,
What am I doing wrong?
https://linustechtips.com/topic/1384475-ddwrt-issues/
Split to its own thread, please don't post in years old threads.
F@H
GPD Win 2
https://linustechtips.com/topic/1384475-ddwrt-issues/#findComment-15071804
Almost all third-party firmware installations have a specific set of instructions for the router flash.
IIRC, for DD-WRT, you should reset to defaults, flash the initial/base firmware, reset to defaults, flash the final firmware, then reset to defaults. Customize as you want thereafter. Did you do this?
Out of curiosity, why not use OpenWRT?
https://linustechtips.com/topic/1384475-ddwrt-issues/#findComment-15071912
Depends on chipset. Some you have to do a 30-30-30 reset in order to do the process, others you just need to do a simple reset.
https://linustechtips.com/topic/1384475-ddwrt-issues/#findComment-15072093
DD-WRT is easier to use for beginners.  I started with DD-WRT, moved to OpenWRT and then went all out with pfSense.  Still using OpenWRT for Access Points.
https://linustechtips.com/topic/1384475-ddwrt-issues/#findComment-15072244
You know what would be helpful for those who were willing to help? If you were to tell us what those problems were.
https://linustechtips.com/topic/1384475-ddwrt-issues/#findComment-15072321
