connect mf120 halo in chain to connect one argb cable to the motherboard
alpablock23
Hello ,
I have a question regarding the cooler master mf120 halo . I would like to use 3 of them as an intake on my case front , these fan are argb and my msi x570 gaming pro carbon only have 2 of these port and they are use for fans . I already own one mf120 but can in connect in chain the argb cable from this fans to only connect one to my motherboard without using the small controller who come with the fan .Like on the drawing who came with my post (brown are the argb cable and the dot are one fan connect with the other ).And will i be able to only control all of the fans with the msi dragon center if they are connect like this (i will only choose rainbow mode )
Thanks for taking the time to answer me
Have a nice day
-> Moved to Cooling
RGB uses splitters, not daisy-chaining. If you buy 3-pack, it includes splitter. While you can split from splitter, be sure you don't go over the 3A (IIRC) max limit per header.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
