Is my AIO cooler working okay?
Nehalem
I recently got a Arctic Liquid Freezer II 240 ARGB and I was wondering if I'm getting the right performance?
I don't have any point of reference so I don't know where I stand.
I have a Ryzen 5800X with a Vega 56 GPU in a Phanteks Evolv X case.
It's hovering at 75C when doing some monero mining and cinebench stress tests.
its still within healthy range for the cpu as long as it doesn't go over 80ish under full load its fine
if your putting the cpu through cinebench its going to get hot bc its under heavy load, if you don't care about noise you can adjust the fan curve on the radiator fans to be more aggressive, but its not exactly necessary in my opinion unless stuff starts to get to the 80-90 Celsius range.
Yeah. It's working cool and quiet but I just wasn't sure if it's working right(?) because on some benchmarks I see it at 50C unless those are deltas.
And I'm testing on a room with AC on full blast.
50c is likely a delta.... no CPU is going to run at 50c while under load on any cooling solution that is based on ambient temps. 75c for cinebench is a bit warm since it's not that intense of a load, but that is within normal range, just a bit on the high side I would say. Id expect high 60's to low 70's, but 75 is totally normal.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
